Creating Token for Portal for ArcGIS
549
11-28-2022 10:00 PM
Tarunvisvanadula1994
Is it Possible to Create token for Portal for ArcGIS with expiry time of One year ?
I have tried to use generate token method and provided expiry time for next year date. Still the token got Expired after two weeks.
Thanks
Tarun V
Scott_Tansley
MVP Regular Contributor
https://enterprise.arcgis.com/en/portal/latest/administer/windows/specify-the-default-token-expirati...
Most Penetration Test and Certification and Accreditation have suggested that two weeks is a bad idea, and it should be a max of a long working day 8-10 hours.  It's your call on how you change it, but 1 year could create a security issue.
Have fun.
Scott Tansley
https://www.linkedin.com/in/scotttansley/
