Create Service exception ' Exception: Connection refused: connect'
1318
02-07-2019 02:52 PM
PeterOfori-Atta2
I keep getting this error when i attempt to create a survey on my portal through survey123 web.
Someone kindly help
DerekLaw
Esri Esteemed Contributor
Hi Peter,
What release of Portal for ArcGIS are you using?
Have you reviewed the contents of this Esri Technical Article:
How To: Configure Portal for ArcGIS to work with survey123.arcgis.com
Hope this helps,
