Combining Portal for ArcGIS Named User Licenses
3735
09-06-2015 03:40 AM
BadarGillani
New Contributor II
ArcGIS for Server Advanced Enterprise is entitled for 50 names user licenses. In case an organization has two Advanced Servers can the named user licenses clubbed together for use on a single instance of Portal for ArcGIS? and how?
AGS-1 (Adv.) 50 named users + AGS-2 (Adv.) 50 named users = 100 named users (serviced through single portal instance)
Thanks
Badar
DerekLaw
Esri Esteemed Contributor
Hi Badar,
Q) In case an organization has two Advanced Servers can the named user licenses clubbed together for use on a single instance of Portal for ArcGIS? and how?
Yes, in the scenario above you can combine the named user accounts that are included with the 2x Advanced ArcGIS for Server licenses into a single Portal for ArcGIS instance.
Please contact Esri Customer Service (or your local Esri Distributor) and they can generate a new license file for you to deploy.
Hope this helps,
BadarGillani
New Contributor II
Hi Derek,
Thanks and appreciate response and clarification. It is really helpful. Will contact Customer service for generating the license file.
Regards,
Badar
