Clone items fails with message "Access to admin resources are not allowed\n(Error Code: 403)"
2593
6
10-01-2021 03:56 AM
suryakant_cssl
I am trying to clone some hosted feature services from one Portal (10.6) to another (10.8.1). I am an admin and logged in via OAuth 2.0 (with client_id) on both the Portals. The items are owned by another user but I am an admin on both Portals and I can view the layers in map viewer. The [clone_items] method provided in ArcGIS Python API is failing for all hosted feature services with the following message.
"('Failed to create Feature Service Wetlands: Access to admin resources are not allowed\n(Error Code: 403)', <Item title:"Wetlands" type:Feature Layer Collection owner:Surya.Kant@domain.com>)"
I am able to clone the scene services successfully but unable to clone even a single feature service due to the above message.
Any help will be highly appreciated.
JakeSkinner
Esri Esteemed Contributor
Hi @suryakant_cssl,
If you have a built-in or active directory account for Portal, you can use the following tool to copy services:
https://community.esri.com/t5/arcgis-enterprise-documents/copy-content-between-portals/ta-p/920460
suryakant_cssl
Thanks a lot Jake,
I will give it try and post back the results.
Regards,
Surya
conghuang1
I have the same issue, I want to try my own code, and for other layers the clone_items working fine, just for hosted feature service, has the same error.
JTessier
We are having a similar issue (same error message), but just with automating publishing via the python api.
@conghuang1did you ever find a solution?
mgress12
Following an upgrade to 10.9.1 we are now seeing this error message when using the python api to clone hosted feature layers. This was not an issue at 10.7.1. Any tips on getting this to work?
AdrianHughes_ESRIUK
I'm seeing this issue when attempting to clone Survey123 from AGOL to Enterprise (10.9.1)
