Clip to shape-specifying one file
1121
06-16-2010 05:10 AM
AnnieCahill
Is there any way to clip one data layer to a shapefile when you have several which lie outside the boundary?  I need to do this without actually changing the dataset.  I didn't see anything allowing me to specify just one shapefile to be clipped but I thought some of you would have more ideas.  What I have is a county boundary with several shapefiles which extend outside the boundary, but I need to make sure one doesn't show up outside the boundary.  Any ideas?
Annie
JohnSobetzer
Honored Contributor
If you can't change the dataset you want to "clip", you are limited but depending on your TOC display order, you might consider creating a polygon big enough to hide that data, then cutting out of that polygon a donut hole to match your "clipping layer", and the put this masking poly over the layer to be "clipped" in the TOC as a white poly.  It will hide everything below it on the TOC, however.
DanaNolan
You can use a select by location, then Selection/save selected records as a layer. This new selection layer will have only the records that fall within the shapefile (you will also have to copy/import your symbology from the original layer). That will not, however, clip the overhangs.  I agree that they would need to be covered with another layer.
