Cannot publish to portal
4736
20
01-06-2023 12:09 PM
Laura
by MVP Regular Contributor
For whatever reason I have been getting a failure to publish error when publishing to portal. I can publish to AGOL just fine. I've been on numerous calls with Esri customer service as well as pulling in outside sql help to play around and look for what may be the problem. No one can find anything. A waste to pay this much money and not be able to use the service.
Laura
How do I go about changing that? I always use an sde connection path.
