Callout snapping
2358
03-14-2012 01:29 PM
ColinRicks
I want to insert annotations in layout view and have them snap to guides I have set up.  However, instead of the callout snapping to the symbol, it snaps to the text.
The attached image illustrates the problem.  What I want, is to have the border of the callout snap to the guide.  Is there a way to do this?
[ATTACH=CONFIG]12680[/ATTACH]
CarsonGarver1
Reduce the size of the left and right margins.
or position it so it snaps to the guide then use Shift+Arrow Keys to move it to the desired position.
Shift+Arrow key moves it a small distance.
Arrow Key will move it  mid distsance.
Ctrl+Arrow key moves it a large distance.
The distance these move is also dependent upon your current layout extent (Not map extent)
ColinRicks
This is what I have been doing, but it's very tedious when there are a large number of annotations.
I need a margin around the text, and I am trying to line up the callout border with the dataframe border.  It is nearly impossible to get these borders to match and not look weird when printed.
