Azure Ad and Portal Integration
1476
04-27-2018 12:46 PM
PaulGiard
I am integrating Azure Ad with a local instance of Portal.  I am following the walkthrough here:https://docs.microsoft.com/en-us/azure/active-directory/active-directory-saas-tutorial-list
Since I am using Portal and not ArcGIS Online I am confused on where to get the URLs for Sign On and Identifier
What am I missing?
JacobBoyle412
So the steps are the same, with the sign on URL being: https://portal.yoururl.com/portal and Identifier set as portal.yoururl.com/portal
Jacob is a Sr. Solution Architect for Esri Professional Services and loves conservation planning, woodworking, LEGO, and his dogs.
PaulGiard
I was able to get this working.  I added a Non-gallery application from the Enterprise Applications.  A walkthrough for the required steps for Enterprise Portal would be helpful.
1.  Azure AD\Enterprise Applications\New Application
2.  Select Non-gallery Application
3.  Follow the steps for Single Sign-On
