ArcGIS for Portal 10.5.1 - Import Insights for ArcGIS Entilement
886
05-09-2019 11:43 AM
VarunK_R
Hi
Has anyone else setup an ArcGIS for Portal 10.5.1 site and tried to import their Insights for ArcGIS Entitlements form the 10.5.1 License Manager
We are getting this error
{   "error" : {     "code" : 500,     "message" : "java.lang.RuntimeException: The entitlementsFile is missing the 'arcgisInsights' or 'files' attribute.",     "details" : null   } }
MarleyGeddes
Hi Varun,
Insights for ArcGIS does not require licensing through the License Manager.
To license Insights for ArcGIS, import the .json license file downloaded from My Esri directly into the Enterprise portal. You import the license file into Portal in the Portal Administrator Directory under System > Licenses > Import Entitlements.
Here is the documentation on configuring Insights for ArcGIS licenses for ArcGIS Enterprise 10.5.1: https://enterprise.arcgis.com/en/portal/10.5/administer/windows/configure-insights-licensing.htm
Hope this helps,
Marley
