Dears Alian and Christopher,
thank you for your reply. I've a EC2 instance (t2.xlarge with 4 vCPU) on AWS. Today I 've unistalled all Esri components and deleted all old directories. Now I installed Portal for ArcGIS (Portal_for_ArcGIS_Windows_110_182885.exe) only where i provided the following information during the installation steps.
Also I used D:\arcgisportal like home directory instead of C:\arcgisportal
The installation has been completed without error but opening web browser at https://ec2amaz-1vfuf0p:7443/arcgis/home or http
I got the following error:
Looking in physical path c:\intetpub\wwwroot the folder arcgis\home doesn't exist and in IIS there isn't virtual directory.
The log file (see xxx.log) contain the following verbose message:
The process monitor did not find the connection to the configuration store. The site may not have been initialized. After the site is initialized, the check for database processes will be reattempted.
Do you have any idea? It's a just the new first step....
Thank you in advance.
Giuseppe P.
