arcade code problem: varying years
1571
03-09-2023 08:05 AM
SoleneMas
Good morning,
I try to create a code with arcade, allowing to create a dat value according to several conditions.
I have a tree data that contains fields not_diag, periodicity, date_diag and maj_previsionnel which is the field where the value should appear.
if the not_diag field is not empty and the periodicity includes 1 then maj_previsionnel=date_diag +1 year
So make this condition on the four periodicity values.
I wrote the code this way below. The problem is that it doesn’t display anything, so I don’t know if it works or not.
HELP 😃
If($feature["note_diag"]!="" && $feature.periodicite=="1") {
return ($feature["maj_previsionnelle"])= Dateadd($feature["date_diag"],1,'years');
else{
If($feature["note_diag"]!="" && $feature.periodicite=="2") {
return (maj_previsionnelle)= Dateadd($feature["date_diag"],2,'years');
else{
If($feature["note_diag"]!="" && $feature.periodicite=="3") {
return ($feature["maj_previsionnelle"])= Dateadd($feature["date_diag"],3,'years');
else{
If($feature["note_diag"]!="" && $feature.periodicite=="4") {
= Dateadd($feature["date_diag"],4,'years');
DavidPike
MVP Notable Contributor
if ($feature["note_diag"] != "" && $feature.periodicite == "1") {
return Dateadd($feature["date_diag"],1,'years')
else if($feature["note_diag"] != "" && $feature.periodicite == "2") {
return Dateadd($feature["date_diag"],2,'years')
else if($feature["note_diag"] != "" && $feature.periodicite == "3") {
return Dateadd($feature["date_diag"],3,'years')
else if($feature["note_diag"] != "" && $feature.periodicite == "4") {
return Dateadd($feature["date_diag"],4,'years')
//else {return something}
SoleneMas
Thank you for your offer.
However, no value appears either.
I eassaie to make it appear in the popup is the value is empty knowing that the fields are filled.
Also I wanted to use this technique for collector because we don’t have fieldmap yet, I have a big doubt that this is the right way to automatically propose a value in maj_previsional.
DavidPike
What happens if you set this as the else
else {return $feature["date_diag"]}
what are you data types for periodicite? string or numbers?
