Actions for related tables in Dashboard
1592
01-05-2022 04:53 AM
MohammedElsayed
I have a web map for a layer with related table, then I created a dashboard from it. I can set an action in the map that filters on other visuals but it works only to the feature visuals not the related table visuals. is there anyway that make the related table visuals interact with the map filter actions?
Kanin
by Esri Contributor
Are you using the map actions where the data in chart elements is filtered based on map's extent? I understand that because related tables are not spatial, it is expected to not be filtered based on map pans, zooms etc. Nonetheless, attribute actions will work for non-spatial tables where it is possible to use the relationship key fields as the filter initiator.
Best regards,
Kanin
If this answer solved your question, please mark it as "Accept as Solution" to help others who have the same question.
dhowes1
Shame this isn't possible - my related (non-spatial) table is linked to the map layer by an indexed id field.  Would be really great to be able to filter this based on map extent.
