Open Enterprise Sites gallery items using their own URL
3926
8
04-17-2021 12:06 AM
Status: Already Offered
KeithMiller3
Currently on 10.8.1, Enterprise Sites allows users to use Layout Builder to add a Gallery into a site's page. When a user clicks on one of the gallery items, it opens the link but 'within' the Site rather than outside of the Site.
i.e. the URL of the gallery item is (1) https://<portalURL>/apps/sites/#/<site-name>/app/<site-id>
rather than (2) https://<portalURL>/apps/webappviewer/index.html?id=<site-id>
URL (1) means that the linked app opens in an iframe within the site page (and I get a vertical scrollbar as a result), whereas URL (2) would open the app using its native URL.
It'd be great to have the option of opening gallery items using their native URL rather than being embedded within the Site.
8 Comments
EinarD
This is relevant for 10.9.1 as well. Would be great if one could open web maps in the map viewer directly from the gallery, instead of now having to go through "Explore" --> "I want to use this" --> "Open in ArcGIS Enterprise" --> "open in Map Viewer".
GarthVaagene
Fully agree as this seems to circumvent what a user wants to be able to do with this layout option. Only other way I've found is to use a hyperlink but then no thumbnail or description is presented.
DavidMcCorkindale1
I too came across this problem at 10.9.1 but see there is actually a setting to resolve this.  Under the site go to Settings | Interactions | Embedded Apps, disabling this opens an app from a gallery card by it's native URL.  The settings on the gallery card determine whether this opens in the same or new tab.
Hope this is what you were looking for and has resolve your issue.
KeithMiller3
@DavidMcCorkindale1 Thanks very much. Just tested it on 10.9.1 and works just as you say.
jill_es
jill_es
As @DavidMcCorkindale1 mentioned, there is actually a setting to resolve this.  Under the site go to Settings | Interactions | Embedded Apps, disabling this opens an app from a gallery card by its native URL.  The settings on the gallery card determine whether this opens in the same or new tab.
JessicaJackson
In 11.1, when I disable Settings | Interactions | Embedded Apps, the web maps still open in embedded apps.
Esri support states that the Settings | Interactions | Embedded Apps option does not work in 11.x (although, you can open web applications/experiences directly) for security purposes and is outside scope of support.
Is there a plan to implement the ability to open Web Maps for 11.x from gallery without 4 extra clicks?
timfreisen
I had excactly the same problem with the extra vertical scrollbar. This is some wierd behavior with the header and an iFrame.
I checked the CSS and found that overflow-y: auto; doesnt make sense when the site has approximatly 99% of the vertical height when there is a header.
So either we have the choice of an scrollbar with the global header of ArcGIS Site or no header and no scrollbar.
But what if you want the header in the opened item but dont want the scrollbar to appear?
