Grant View Privileges and Revoke Edit Privileges Simultaneously in Change Privileges Tool
889
12-17-2012 02:54 PM
Status: Closed
NathanHeick2
The geoprocessing tool Change Privileges should support the parameter combination View = "GRANT" and Edit = "REVOKE".  Currently, the tool will only validate for revoking editing privileges using the parameters View = "AS_IS" and Edit = "REVOKE".  I understand that you can't have edit privileges without SELECT privileges first, but the combination makes sense to me.  In the end, I want viewing privileges, but not editing privileges.  There isn't any ambiguity in the final result I am looking for with those parameters.  To accomplish this now, I have to revoke the editing privileges using View = "AS_IS" and Edit = "REVOKE" and then grant viewing privileges using View = "GRANT".  This takes two steps that could be combined into the logic of the geoprocessing tool instead.
2 Comments
NathanHeick2
One reason this is important is that when I run the script, I don't know if anyone has modified the dataset privileges to grant editing privileges.  No matter what may have happened during the development of our new system, I want to set or reset the privileges to what they should be, either editing or viewing.
SSWoodward
Status changed to: Closed
This idea has been closed as a duplicate of the ArcGIS Pro - Geodatabase Idea linked below. Don't worry, you can still show your support by commenting and adding kudos to the open idea. Thanks for your contributions!
Link to open ArcGIS Pro - Geodatabase Idea
