Enable renaming of ArcGIS Server 10.1's services-folders
993
01-07-2013 10:59 AM
Status: Closed
VictorRutherford1
Allow admins to rename the folders that hold ArcGIS Server's services (in 10.1).
I used to be able to do this as a config change in previous versions, but in 10.1, it seems you can't change this:
http://myServer/arcgis/rest/services/FolderA/service1/MapServer
to
http://myServer/arcgis/rest/services/FolderB/service1/MapServer
We had a folder called ProductXWorld with numerous services running in it, but as things changed we wanted to change it to just World so it was not product-specific, and it seems this is not doable in 10.1 (according to esri-support) so it was suggested I request the enhancement here.
I could see this being useful for many other scenarios as well. Otherwise, it should be much more critically announced in the documentation that these names are written in stone, so more care is used when designing folder names.
4 Comments
DerekLaw
FYI, please take a look at this:
ArcGIS Server Administration Toolkit - 10.1
by Anonymous User
 Pug Idea List 2014:  Derek Law, Dal Hunter, ESRI Leads
Would like more info from customers on why this needs to be done. Core service folders used by services.
SebastienPetit
The toolkit does not allow to rename folders.
Why doing it?
Lets say you have your services (many of them) grouped by themes and you just have a theme that is renamed.
How do you just change the folder name without having to create a new one and republish everything
MaggieBusek
Status changed to: Closed
Thank you for your idea. This will not be implemented at this time.
