Dynamically filtered hosted Feature Layer Views
1670
01-30-2023 02:09 AM
Status: Open
Hannes_Brandt
IDEA: There should be the ability to make filtering of hosted feature layer views more dynamic using ArcGIS Arcade.
Currently the filter settings of a view create a static definitionQuery in the associated service of the hosting ArcGIS Server. For dashboards there is also the possibility to create a data expression which allows such a dynamic filtering with ArcGIS Arcade. This feature would be desirable directly when creating a hosted feature layer view.
USE CASE: One possible use case is that the hosted feature layer view could be filtered by ArcGIS Arcade based on the currently logged in user.
3 Comments
Scott_Tansley
Hannes_Brandt
Hey Scott,
thank you for your comment.
Sadly security.manager (both "Enterprise" and "NEXT" edition) does not support hosted Feature Layers.
https://docs.conterra.de/en/securitymanager-enterprise/latest/userguide/appendix/functional-matrix-i...
https://docs.conterra.de/en/securitymanager-next/latest/index.html
MarcelBeckmann
