Adding fields to Hosted Feature Layer should be visible by default
1107
10-26-2018 04:33 PM
Status: Open
PeterKing
When adding fields to a hosted feature layer in Portal, the fields are not visible by default from the Data Tab within portal. After adding a field, a user must Select Options > Show/Hide Columns and turn on the newly added fields. Kind of annoying since the user is adding the fields for the purpose of using them.
2 Comments
by Anonymous User
Hi Peter,
Thanks for your idea. All fields should be visible by default. May I ask the version of ArcGIS Enterprise you are using? As well, are you seeing this behavior with hosted feature layers and/or are you using hosted feature layer views? Create hosted feature layer views—Portal for ArcGIS | ArcGIS Enterprise
Hilary
PeterKing
Hosted Feature Layer in Enterprise 10.6.1
