Public Function ExportToShapefile() As Boolean
Dim logger As log4net.ILog = LogFactory.GetLoggerService()
Dim featclassName As String="BuenosAires"
Dim pathExport As String="c:\temp\"
Dim fileExport As String"BuenosAires.Shp"
Try
Dim objConsde As ConSde
Dim Owner As String
objConsde = Conexion.Instancia.GetConexionSDE(DataProvidersde.SQLSDEANALYTICS.ToString)
Owner = Conexion.Instancia.ownerAnalytics
featclassName = Owner & featclassName
' Crear WorkspaceName del origen
Dim sourceWorkspaceDataset As IDataset
Dim sourceWorkspaceName As IWorkspaceName
sourceWorkspaceDataset = objConsde.sdeWorkspace
sourceWorkspaceName = sourceWorkspaceDataset.FullName
'Crear FeatureClassName del origen
Dim sourceFeatureClassName As IFeatureClassName = New FeatureClassName()
Dim sourceDatasetName As IDatasetName = sourceFeatureClassName
sourceDatasetName.WorkspaceName = sourceWorkspaceName
sourceDatasetName.Name = featclassName
'Crear WorkspaceName del destino
Dim targetWorkspaceDataset As IDataset
Dim targetWorkspaceName As IWorkspaceName
Dim pShapeFileWorkspace As IWorkspaceFactory
Dim targetWorkspace As IWorkspace
' Abre workspace del destino (path de los shapefiles)
Dim pPropset As IPropertySet
pPropset = New PropertySet
pPropset.SetProperty("DATABASE", pathExport)
pShapeFileWorkspace = New ShapefileWorkspaceFactory
targetWorkspace = pShapeFileWorkspace.Open(pPropset, Nothing)
targetWorkspaceDataset = targetWorkspace
targetWorkspaceName = targetWorkspaceDataset.FullName
' 'Crear FeatureClassName del destino
Dim targetFeatureClassName As IFeatureClassName = New FeatureClassName()
Dim targetDatasetName As IDatasetName = targetFeatureClassName
targetDatasetName.WorkspaceName = targetWorkspaceName
targetDatasetName.Name = fileExport
' Abre definición de campos del origen
Dim pName As IName
Dim pInFC As IFeatureClass
pName = sourceDatasetName
pInFC = pName.Open
' Valida Campos y guarde en campos destino
Dim pOutFCFields As IFields = Nothing
Dim pInFCFields As IFields
Dim pFieldCheck As IFieldChecker
Dim i As Long
pInFCFields = pInFC.Fields
pFieldCheck = New FieldChecker
pFieldCheck.Validate(pInFCFields, Nothing, pOutFCFields)
' +++ Recorre los campos para encontrar el campo geometría (SHAPE)
Dim pGeoField As IField = Nothing
For i = 0 To pOutFCFields.FieldCount
If pOutFCFields.Field(i).Type = esriFieldType.esriFieldTypeGeometry Then
pGeoField = pOutFCFields.Field(i)
Exit For
End If
Next i
' +++ Obtiene la definición del campo Geometría para destino
Dim pOutFCGeoDef As IGeometryDef
pOutFCGeoDef = pGeoField.GeometryDef
' +++ Obtiene la definición del índice y grilla espacial
Dim pOutFCGeoDefEdit As IGeometryDefEdit
pOutFCGeoDefEdit = pOutFCGeoDef
pOutFCGeoDefEdit.GridCount_2 = 1
pOutFCGeoDefEdit.GridSize_2(0) = 0
pOutFCGeoDefEdit.SpatialReference_2 = pGeoField.GeometryDef.SpatialReference
Dim pQueryFilter As IQueryFilter
pQueryFilter = New QueryFilter
' Crear objteo featuredataconverterclass
Dim pFCToFC As IFeatureDataConverter = New FeatureDataConverter()
' Convierte featureclass origen a featureclass destino
Dim pEnumErrors As IEnumInvalidObject
Try
pEnumErrors = pFCToFC.ConvertFeatureClass(sourceDatasetName, pQueryFilter, Nothing, targetDatasetName, pOutFCGeoDef, pOutFCFields, "", 1000, 0)
' Recorre resultado de la conversión y guarda en log
Dim pErrInfo As IInvalidObjectInfo
pErrInfo = pEnumErrors.Next
If Not pErrInfo Is Nothing Then
logger.Warn(featclassName & " - " & pErrInfo.ErrorDescription)
Do Until pErrInfo Is Nothing
Loop
Return False
Else
logger.Info(featclassName & " Export a Shapefile (SEGAT) sin errores")
Return True
End If
Catch ex As Exception
If ex.Message = "No support for this geometry type." Then
CreateShapeFile(pOutFCFields, pOutFCGeoDef, fileExport, "SHAPE", targetWorkspace)
Return True
Else
Throw
End If
End Try
logger.Error(featclassName & " - " & ex.ToString)
Return False
End Try
End Function
Hola, tengo esta funcion que exporta 1 capa de la GEODATABASE a un shapefile, lo haciamos sobre ARCMAP y estamos migrando a ARCGIS ENTERPRISE SDK, y no funciona, los problemas que tenemos son 2
Nos dice que " No está definido el tipo ‘FeatureClassName’"
intentamos cambiar por
Dim sourceFeatureClassName As IDatasetName = New ObjectClassName()
Pero entonces nos pincha en la linea principal
xque solo puede recibir el tipo FeatureClassName
Si nos pueden ayudar, el resto de nuestros codigos fueron migrables, menos este.
Gracias
Saludos,
Anibal
Telecom Argentina
