CDF tool not installed with ArcGIS Enterprise SDK 11.1
2346
13
04-23-2024 02:34 AM
JohnLandeborg1
I'm able to install CDF tool using version 11.2 but not 11.1 downloaded from my esri.
No warning or prompt during installation and the folder customdatacli is not created.
John_Hash
Hello, @JohnLandeborg1
I have a couple comments and suggestions that may help you solve this issue.
1) During installation, does the install wizard give you a warning that either Node.js is not found or that the installed version of Node.js is not supported?
2) ArcGIS Enterprise SDK version 11.2 supports a higher version of Node.js than 11.1. For instance, 11.2 requires a version of Node.js between 16.19.1 and 18.17.0. An appropriate for Node.js version for 11.1 would be 14.21.3 for instance.
3) Are you managing your Node.js versions on your machine with NVM for Windows? I am assuming you are using Windows here, but if you are using Linux, please let me know, and I can change our conversation toward Linux installations. In 11.2, Node.js installations performed with NVM for Windows are supported. In 11.1, I would suggest installing Node.js directly from the download https://nodejs.org/en/download.
So after all that, this is what I would suggest you try at this point:
1 - Uninstall ArcGIS Enterprise SDK
2 - Uninstall your current version of Node.js (regardless of the method you used to install it), and make sure there is no "nodejs" folder in "C:\Program Files"
3 - Use the link above to download and install Node.js 14.21.3
4 - Install ArcGIS Enterprise SDK version 11.1
If you have any questions or concerns before trying these steps, please don't hesitate to reply.
John_Hash
JohnLandeborg1
After I uninstalled nvm (and all node.js) and installed 14.21.3 of node.js was I able to install the SDK 11.1 cdf tool! Now I will go head and try the YELP sample on my ArcGIS Enterprise 11.1! Some modifiacation to the installations instructions is needed? And what to do if I must use nvm?
JohnLandeborg1
The YELP walkthrough endup with a error:
Failed to register custom data provider in 'yelp-data-provider.cdpk'. Failed to register custom data provider in 'yelp-data-provider.cdpk'. Node server failed to start
Somthing is still missing. Network issue? My ArcGIS Server is behind a webproxy,
John_Hash
Did your Yelp provider work in development before you exported it and attempted to register with ArcGIS Server?
On your ArcGIS server machine, you can check here to see more specific errors:
ArcGIS/Server/framework/runtime/customdata/logs
JohnLandeborg1
Yes I did get a result on develoment (localhost:8080/yelp-data-provider/rest/services/restaurants::redlands/FeatureServer/0/query)
Serverlog added below. The log ends in a error:
"address already in use :::6843"
John_Hash
Looks like for some reason that port isn't free. That is the port that the Custom Data Feeds Node.js app runs on. Try killing the current process on port 6843. The CDF app will automatically restart itself.
Kill Processes on Windows
Kill Processes on Linux
JohnLandeborg1
I tried >12 hour later and now it works! I dont think anyone restart our ArcGIS developer machine, så the process must died on its own. My original error must be that it didn't work with my nvm installation, is it correctly interpreted?
Matth1
@John_Hash  using 11.4 enterprise sdk. sdk install does not find node install when using nvm. any tricks?
JohnLandeborg1
Still in version 11.3 and I never got it to work with nvm.
