Arcgis 11.1 SOI not return username for feature server
1209
09-01-2023 05:57 AM
Dvirus
var serverUtilities = ServerUtilities.GetServerEnvironment();
var username = serverUtilities .UserInfo.Name
username return null
I tried to
"disableCaching": "true",
even it's only affected on MapServer.
This bug occurs also in version 10.9.1 - fully patched.
Amir-Sarrafzadeh-Arasi
Dear Dvirus,
Please try this for getting the username,
IServerUserInfo userinfo = ServerUtilities.getServerUserInfo();
String user = userinfo.getName();
Amir Sarrafzadeh Arasi
Hi Dvirus,
I solved the problem, it depends on your operation name, when you do not separate the operation names the request return null for the username,
Please double check your script and check the operation name in the first line of the SOI.
Hope it helps
