Configure Pop-Up with hyperlink for Map Service in ArcGIS Earth
528
09-20-2022 11:22 AM
ABishop
MVP Regular Contributor
Hello fellow GIS'ers,
I would like assistance with configuring a pop-up with a hyperlink in ArcMap or ArcGIS Pro, publishing it as a map service, then adding it to ArcGIS Earth, and having the hyperlink show up in the pop-up.
I have tried both ArcMap and ArcGIS Pro (HTML, Arcade, and plain field displays), and nothing has worked.
Please help!
Amanda Bishop, GISP
ben_tan
New Contributor II
Hi Amanda Bishop,
Thank you for your feedback. We have logged the issue and started tracking it.
The current version of the ArcGIS Earth pop-up should support HTML, hyperlinks, etc. It does not support "Arcade/expression" for now.
In order to locate the problem faster or provide other possible solutions, I would like to confirm with you further whether the data you are using is a "map image layer" type.  Can you provide a URL to the test data?
Ben
ABishop
Hi Ben,
The REST URL is private to our organization.  Are you able to get to it?  I can send it to you in a private message.
Amanda
Amanda Bishop, GISP
ben_tan
New Contributor II
Hi Amanda,
I have received a private message from you. And I also attached a test data we generated in my reply.
From the test results, it does appear that ArcGIS Earth does not currently support pop-ups with hyperlinks configured from ArcGIS Pro, etc.
We have launched a series of investigations into this issue and have not yet found a suitable workaround for the user side. Due to the development cycle, support for this type of popup will probably be put into a version after 1.17.
Feel free to contact us further if you have any questions.
All the best,
Ben
