ArcGIS Earth Functionality
4401
10
01-03-2018 06:33 AM
RomaHicks
Will Earth support Layer Packages (*.lpk)?
Support the rendering of feature labels?
We use Explorer Desktop in production as we handle sensitive data that web portals are not appropriate for use.  It is kind of bad form that Explorer Desktop was retired and Earth's functionality makes it only slightly better than toy software.
Is there a ticket centre, road map, mailing list, etc. that shows progression of the development of this software?
Tags (1)
DanPatterson_Retired
Have you seen the docs?
http://doc.arcgis.com/en/arcgis-earth/
RomaHicks
Yeah, I have searched the little bit of documentation, gis.SE, and Googled every way I could think.  Any case the official documentation speaking nothing about labeling (which would be most important to me).  KML hacking could get the labels from what I have found, but that is not ideal.
it is largely a viewer, it sounds like you are looking for data processing capabilities.  Those sorts of things are for the paid software offerings.
JoshuaBixby
MVP Esteemed Contributor
Even with Esri's paid software, road maps of any kind are basically nonexistent.  For ArcGIS Pro, Esri has been trying to put some very high-level road map stuff in GeoNet, but it is far from extensive information.
BenTan
by Esri Contributor
Hi Roma, Thanks for your feedbacks.
  • Supporting layer packages is under consideration. (Issues about it are in the future release plan)
  • ArcGIS Earth will support the rendering of labels in the near future. (We need fix some bugs related to it)
JoshuaBixby
Ben Tan‌, you seem to be in-the-know with ArcGIS Earth.  Any plans for the development team to set up something similar to https://community.esri.com/community/gis/applications/arcgis-pro/blog/2017/07/10/arcgis-pro-roadmap ?  If not, I strongly encourage it.
BenTan
by Esri Contributor
Hi, Joshua. I am a developer in ArcGIS Earth team. I have told your suggestion to others in the team.
We currently don't have a public road map like you mentioned above.
Thanks for the good suggestions!
We will set up one after arranging the materials about it.
JoshuaBixby
Ben, thanks for the prompt reply, much appreciated.  If you do set up a high-level road map of sorts for ArcGIS Earth, I suggest using a "Document" instead of a "Blog" for sharing the information.  The ArcGIS Pro team decided to use a blog, but I find it rather messy for several reasons covered in the comments to their road map blog.
BenTan
by Esri Contributor
Hi Joshua. Thanks for your suggestion again. We got it now.
Have a nice weekend!
