Option to use modifier key + right click to link to a URL
868
07-06-2022 12:42 PM
GISAdmin39
This is similar to the current implementation of positionsServiceUrl, which allows linking to a valid KML file. I propose a configurable option to allow linking to a custom URL scheme.
The current "default" implementation in config.xml looks like:
<urlwithpos>http://127.0.0.1:8585/pointBasedService?lon=%LONGITUDE%&amp;lat=%LATITUDE%&amp;elv=%ELEVATION%&amp;output=.kml</urlwithpos>
It would be nice to have a configurable URL scheme along the lines of:
There are a couple of variations of that URL schema that might also work.
2 Comments
Sharon_MU
Hi @GISAdmin39 ,
Thank you for the great idea !
I found the URL you posted was truncated.  it might be that I copied from the hyper link address as following:
https://clientsuppliedmappingserviceurl/maps/@?api=1&map_action=pano&viewpoint=LATITUDE%2C-LONGITUDE&heading=0&pitch=0&fov=120
If my understanding is right,  the decoded URL is as following:
https://clientsuppliedmappingserviceurl/maps/@?api=1&map_action=pano&viewpoint=LATITUDE,-LONGITUDE&heading=0&pitch=0&fov=120
General speaking,  ArcGIS Earth will check the parameters included by the "%" pair in the URL. (e.g. %LONGITUDE%, %LATITUDE%, %ELEVATION%).  So, ideally the request URL could be in a more flexible way by including the specific parameters.
Not sure if you have a chance to try the parameter in this format, viewpoint=%LATITUDE%,-%LONGITUDE% ?
If the service supports to return KML file,  it would work using the above parameter.
Please feel free to share your findings , questions or anything related I can help.
Looking forward to your feedback.
Sharon Mu
jsphillips
@GISAdmin39 Did the information @Sharon_MU provided you help? Would like to hear your feedback so I can decide if this idea is still open. Thank you in advance.
