KML files drawn in ArcGIS Earth supports labeling
523
10-31-2025 02:32 AM
Status: Open
VirginieLe_Gal
Labeling in ArcGIS Earth is not supported for the KML format. (https://doc.arcgis.com/fr/arcgis-earth/use/apply-label.htm).
Activation is sometimes possible, but problems arise with the layout tool: the label disappears below the background layer. (photo1 : View in ArcGIS Earth with labels - photo 2 : Labels disappear from the layout)
Please add the ability to use labels with KML files drawn in ArcGIS Earth.
1 Comment
GeoffroyRicher-Lalonde
Bonjour @VirginieLe_Gal ,
In the KML format, you can only apply labels for points. The dev team did a nice job developing a functionality to add labels for KML lines and polygons inside ArcGIS Earth (you still won’t find this in Google Earth). But you did find a bug : the disappearing of the labels under the terrain in the Export view.
Here is a workaround : turn off the Terrain3D elevation service in the Terrain menu :
Your labels will be visible in Export 🙂
