Enable vertical exaggeration for Features as well as Surfaces
705
04-23-2025 07:03 PM
Status: Open
Marc_Graham
Hi there,
Vertical exaggeration of the ground is great for emphasizing terrain. However it falls over if you have 3d features that you still need to compare to the ground.
For example I have an OIS generated by ArcGIS Aviation. I would like to exaggerate all 3D heights in the view. However I can only exaggerate the terrain. I should be able to exaggerate z values for everything, the same way I can do this in ArcGIS Pro.
Marc
