The projection system is automatically changed to UTM Zone 18S
989
06-06-2022 10:10 AM
DiegoEslava
Hello everyone, I have the following problem:
when creating a full 2D rendering template, I want to generate a first orthomosaic on which to add the GCPs.
however, and despite the fact that I configure the projection system both in my project and in the processing options and apply the changes to define CTM12(WKID 9377)
but when the product is processed and added to the project the projection system is not the one previously defined.
then the obtained orthomosaic is projected arbitrarily on WGS 1984 UTM Zone 18S.
DianaCarolinaFonseca
Hi!
I have realized that Drone2Map is not recognizing the wkid 9377, while ArcGIS Pro does it. However, I've created a new projected coordinate system in Drone2Map with the parameters related (9377) and the products are generated under UTM Zone 18N.
Drone2Map coordinate system:
ArcGIS Pro:
Any plans to update this system coordinates @DroneMap ?
Regards,
DianaF
