Oriented Imagery Drone2Map OICtype
1109
04-25-2021 05:08 AM
MatthewC
I added the Drone2Map.oictype and the Drone2Map.py per the instructions here oriented-imagery/CustomTypes at master · Esri/oriented-imagery · GitHub   Per the instruction I created  new OIC, then when I use the Add Images to the Oriented Imagery Catalog and choose Drone 2 Map for the Input Type Field then nearly all fields get the red X mark denoting an error.   I'm not yet savy enough to understand the errors.  Anyone else having this issue?
RandallRebello
Hi @MatthewC
I have made a fix for this. The issue was that oictype was not a valid json file. Its now fixed in github. You can download it again to avail of the fix.
Randall
