Improve Accuracy by using DEM Height instead of EXIF
2792
07-16-2017 03:24 AM
GünterDörffel
Hi everybody,
I had recently processed a series of drone flights over densly closed forest. Hardly any ground visibility at all. Results were "sub-optimal".
The first thing I wanted to improve upon were very bad height-values stored in the EXIF of the images. I luckily have a DEM and was able to improve the results (especially the location/scaling) considerably.
The drone data was from a DJI 330 on a Phantom4 consumer drone. I learned that it actually only has a height value stored for the starting point and then the flight height as such. So the "individual" height values on each image were pretty off because the start-height was off. To improve, I followed this workflow:
  • Exported EXIF of all imges in a folder to csv using EXIF-Tools  (If I improve that, I'll use a python exif extractor)
  • Modify elevation/height in csv with height from Starting point PLUS Flight height
  • (Optionally also convert WGS84 X/Y into projected coordinate system including transformation
  • After loading images to Drone2Map replace the elevation by reading in the csv file
  • Process ...
I have all this in python and would actually be willing to share as a toolbox - but would like to have some community-input first:
  • Is this the way to go?
  • Any suggestions what to include in addition?
  • Has anyone got an idea how "valuable" YAW/PITCH/ROLL values stored by a Phantom4 are?
    (and how to make use of them in Drone2Map?   Photoscan/AGIsoft seems to be able to read/use them)
So fire away ... 🙂  Thanks
ChrisToynbee1
Hi Günter,
I know this was a long time ago but I am new to this field and have only just come across your post. From what I have been reading it sounds like your suggestion is a good one and for me (as i say I am still new to this) sounds like the way to go. I don't know if Drone2Map has now made it possible to incorporate yaw pitch and roll, but I think that level of detail would only improve the photogrammetry process, so worth keeping that data if possible.
I am surprised nobody else has messaged on here but I would be keen to take a look at the toolbox you made if you are happy to share?
Thanks for posting.
Chris
JasonMartin3
Sounds like a useful toolbox! Have you come to any conclusions? I'm am still learning and messing around with settings, but have had very little luck with forested landscapes.
Jason
MervynLotter
MVP Regular Contributor
Hi Gunter
I too would find such a toolbox useful. I have a DJI Phantom 4 Pro. I have suggested that a similar function to be added to Drone2Map whereby the user needs to provide (1) a fixed altitude of Drone takeoff site, and (2) the height of the flight, and then the image properties would accordingly be corrected. Do see https://community.esri.com/ideas/15040 . However I don't know if this will ever be implemented as it is not yet in product plan. So your proposal sounds like very useful functionality to  have.
