Import Drone Overlay Data
1652
04-17-2025 07:44 AM
BrandieHegler
Hi there! I am not sure if this is where I need to ask this question, but this is the first time I have posted a question and I wasn't sure where else to ask. I work for the county and our sheriff's office has asked if I could share our address layer to be uploaded as a overlay map on their drone remote. They are wanting the address labels to show up. They are using a DJI RC Plus overlay controller requiring data to be in MBTiles format.
In my first attempt I converted our addressing feature class into a GeoJSON in pro. I then used quickmaptools.com to convert the GeoJSON into MBTiles. This did not work.
I would greatly appreciate any insight or guidance.
MarkBarker1
Hi @BrandieHegler ,
We don’t support MBTile format within Drone2Map or ArcGIS Pro natively. If you have the Data Interoperability extension for ArcGIS Pro then that format can be read and written. https://pro.arcgis.com/en/pro-app/latest/help/data/data-interoperability/supported-formats-with-the-...
If you have access to the above mentioned extension then you could either post within their community forum or reach out to Esri technical support. In either case, they should be able to help you try and solve your issue.
Regards,
Mark
