Fails more often than not -
1744
11-24-2016 07:31 AM
MichaelRobb
Honored Contributor
Nothing more exciting that waiting 2 days for Drone2Map to Crash on 3041 raw images.
Re-run and it hangs on hour 40+ with no logs. Had noticed Drone2map had several instances of itself running.
Try a different area with under a 1000 tiles and now get this:  (at72% complete)
I have the logs at Info and there is nothing in them other than what is also seen in the Error dialog.
Is anyone having this much trouble with Drone2Map?
MichaelRobb
Honored Contributor
No one?
I can pick 50 images, it works. gets to 100% and have a complete output
I try 250 Images, it works, gets to 100% and have a complete output
I add 900 images.. it fails
I add 501 images, it fails.  72%
JamesTaylor3
Esri Alum
How much free disk space do you have of the drive on which the project is stored?
Here's the recommend free space:
  • Small projects (under 100 images at 14 MP): 4 GB RAM, 10 GB HDD Free Space.
  • Medium projects (between 100 and 500 images at 14 MP): 8 GB RAM, 20 GB HDD Free Space.
  • Large projects (between 500 and 2000 images at 14 MP): 16 GB RAM, 40 GB HDD Free Space.
  • Very Large projects (over 2000 images at 14 MP): 16 GB RAM, 80 GB HDD Free Space.
MichaelRobb
Honored Contributor
Hi james,
I am still not ruling out another security or some sort of malware process that causes this.
The Workspace has 100GB.
I have also discovered that one batch of 999 images had one corrupt image, which Drone2Map does not let the user know...
