Export Volume Measurements as SHP or Feature
1666
01-17-2020 12:29 PM
KennethCompton
I think this is more of a product enhancement request.
I know we are able to get volume measurements in the Drone2Map tools. Is there a way to export those volume drawings as a shapefile or a feature class to be saved later and possibly used again?
For me: I have pilots that fly drones for a site and get requests from volume changes for those sites. I would love to be able to upload the shapefile of a volume measure and rerun the volume for that same polygon and get the new measurement for the new flight. Essentially I want to take away the variable of change when you have to redraw the volume calculations.
An even better option would be to give this volume calculation power to my project managers by producing a Web Application with my imagery and a Volume Calculator widget. This would give the project managers (who know more about the sites) the ability to make their own, more accurate, volume calculations.
Any thoughts and help would be fantastic.
James_Wright
Hey Kenneth,
I know this was a while ago and I hope you have since figured it out. However, if you haven't there is a way for you to access measurements as a feature class.
See the screenshot, but essentially whenever you create a measurement (in my example a volume calculation). It does actually save that measurement in this case a polygon with the measurement results as attributes in the project geodatabase. It is located under Image_Mensuration.
I too would love a widget to be able to do this in WAB or experience builder, fingers crossed that happens soon.
Hope that helps for now.
- James
