ERROR DRONE2MAP
2046
07-21-2016 03:48 PM
Maria_ElenaPezoa
Hola,
Estoy utilizando DRONE2MAP y tengo el error. Leo los datos in problema.
Se agradece la ayuda.
Maria
DanPatterson_Retired
are you sure your coordinates are GCS WGS84?  The values listed seem to reflect a projected coordinate system
Maria_ElenaPezoa
Hi,... I am using WGS84, UTM ZONE 19 S......
Ok... the coordinate system must have been truncated, the values are appropriate then, so that can be ruled out.
AnthonyMason
Maria,
Does your imagery contain Yaw, Pitch and Roll data? There is a known issue with imagery containing this information that will be fixed in an update being released next week.
Thanks
Tony
