Drone2Map will not install
2856
10-18-2016 02:45 PM
JonDewalt
Drone2Map will not install.  It keeps asking for the C++ runtime 2008 Redistributable even though i have already installed it.
JamesTaylor3
Esri Alum
Jon,
  You need a specific version of the Microsoft Visual C++ 2008 Redistributable: Version 9.0.30729.6161
Download Microsoft Visual C++ 2008 Service Pack 1 Redistributable Package MFC Security Update from O...
Not sure if this is the problem but it may worth looking into.
jt
DanPatterson_Retired
There are a number of threads using .... drone2map 2008 ... yields numerous hits of various bits of info... you might want to have a read .... https://community.esri.com/message/633164-re-drone2map-samples-not-processing-not-yet-answered?comme...
JonDewalt
I looked at most of those and non refer to issues installing Drone2Map.  I have uninstalled and reinstalled the C++ package and it still will not install.
Jon... It might  be a wider issue with your system.  Since you didn't find any links with that error and a drone2map install, it might not exist with others but only on yours.  I would contact tech support with your details.
JamesTaylor3
Esri Alum
Jon,
jt
JonDewalt
Yes. That did the trick. Thanks
