Drone2Map OBJ and SLPK quality
3612
13
10-06-2023 03:41 AM
MarcelVasicek
I have an issue with creation of 3D model of a building in D2M. The .slpk in D2M and also in ArcGIS Pro looks great, but when I open the .obj file (which is my main goal), it looks absolutely horrible (see below). I have tried opening it in City Engine, Meshlab and Blender and it was the same, so the issue must be with the format or export from D2M. I've tried .dae, but I cannot open the exported file in any software, not even City Engine, so I cannot check the quality. Has anyone encountered problem like this?
BenjaminMittler
Thanks Mark!
That makes sense, i hadn't checked cloud compare but it shows as expected with global shift applied. I was actually able to view the obj correctly in blender and other software after running the python script @PierreloupDucroix  outlined here: https://community.esri.com/t5/arcgis-drone2map-questions/drone2map-obj-and-slpk-quality/m-p/1673193#...
PierreloupDucroix
MVP Regular Contributor
I made a script that will shift coordinates of your OBJ file. The result can now be opened in Blender with a normal looking render :
Be careful because the coordinates have now been altered and precision has decreased.
Here is the sample code that you may adapt and test :
input_filename = r'D:\pathTo\Mesh.obj'
output_filename = r'D:\pathTo\Mesh_modified.obj'
# Adapt shift here
x_shif = - 18533500
y_shift = 2538800
with open(input_filename, 'r') as f_in, open(output_filename, 'w') as f_out:
    for line in f_in:
        # Check if the line starts with 'v' followed by a space (to exclude vt, f, ...)
        if line.startswith('v '):
            parts = line.split()
            # parts[0] is 'v', parts[1] is X, parts[2] is Y, parts[3] is Z
            try:
                x = float(parts[1])
                y = float(parts[2])
                z = float(parts[3])
                # Apply the requested shifts
                new_x = x + x_shif
                new_y = y + y_shift
                # Z remains unchanged
                # Write the modified line
                f_out.write(f"v {new_x} {new_y} {z}\n")
            except ValueError:
                # In case of parsing error, write the original line
                f_out.write(line)
        else:
            # Write lines that are not vertices (vt, f, comments, etc.) as is
            f_out.write(line)
print(f"Done. The modified file has been saved as '{output_filename}'.")
CEO of MAGIS
BenjaminMittler
Thanks Pierre, this helped immensely!
PierreloupDucroix
