Drone2Map Monthly Limits?
1564
10-07-2019 11:58 AM
MichaelOwens
I am trying to find out if Drone2Map has a limit (monthly or annually) for the number of projects and/or images that you can process with a single subscription. For example, I believe Pix4Dmapper has a limit of 10 projects or 2,500 images per month.
Thanks!
-Mike
CodyBenkelman
There are no monthly limits.  As of today (Drone2Map version 2.0) the only licensing available is "named user" which must authenticate through ArcGIS Online or ArcGIS Portal, but there are no limits on # of projects or # of images.
At the 2.1 release we will add the "Single Use" license option which will not need to authenticate with a portal.
Cody B
CodyBenkelman
Cody B
MichaelOwens
Thanks Cody! This answers my question.
