Drone2Map Error 999999 still not fixed...
3094
02-13-2023 06:31 PM
janniewu
Hi, the error 999999 on Drone2Map when running analysis is still not fixed. I have obtained new data, tried both adjusting images attitudes and using the original images altitudes for analysis, but I am still facing the same problem.
The link to my previous post regarding Drone2Map Error 99999: https://community.esri.com/t5/arcgis-drone2map-questions/error-999999-drone2map/m-p/1256768#M1249
Grateful if solutions can be provided.
Pål_Herman_Sund
Hi @janniewu if you were a Norwegian client I would here have asked for a small subset of the imagery (for example the approx 50 images to the east in your screenshot) jut to verify if it id possible to process the imagery.
The 2 errors with respect to mosaic dataset.. may indicate problems with the geoprocessing environment/python. Have you tried to do a repair on the Drone2Map installation? If not that would be my first step
Pål_Herman_Sund
janniewu
Apparently processing did not work when I was using Drone2Map 2022.1.2. Processing worked after upgrading to Drone2Map 2022.1.2.
