Is there a deep learning installer for Pro 2.7?
I'm working through the Detecting Objects with Deep Learning course on Esri Academy today, followed the instructions to the letter and its failing the same way it has been for a few others:
I installed the TensorFlow library from the ArcGIS Pro Package Manager following the course instructions. By default it installed v2.3.0.
The DeepLearning_FAQ.pdf lists the Tensorflow version 2.1.0 as supported for Pro 2.7
Is it necessary to uninstall Tensorflow (and any other of the 98 packages listed for 2.7) and make sure it matches the version listed in the FAQ?
Some libraries - such as tensorflow-base is listed in the FAQ as supported in Pro 2.7 at version 2.1.0, but the Pro 2.7 package installer does not allow the installation of that version.
