Deep learning Model Deployment error in ArcGIS pro
6875
13
07-27-2020 03:02 PM
RitikaPrasai1
Hello everyone,
I am trying to use the developed deep learning model to classify my raster in arcgis pro but when I give .emd file as the input (from deeplearning package) , it says invalid file- could anyone suggest me what is the cause? I have already installed all the packages and environment required for this project. Thank you! Please fine the screenshot attached.
DanPatterson
MVP Esteemed Contributor
From one thread....
The solution that works for me: in Pyhton Package Manager > Add Packages > Search tensorflow and install TensorFlow-mkl 1.13.1
Deep Learning Object Detection Error: Unable to initialize python raster function with scalar argume...
I assume you are using Pro 2.5?
https://pro.arcgis.com/en/pro-app/help/analysis/image-analyst/pdf/deep_learning_install.pdf
... sort of retired...
RitikaPrasai1
I am using 2.5.2. Thank you for your quick response!
DanPatterson
You might as well have this
https://www.esri.com/content/dam/esrisites/en-us/media/pdf/install-deep-learning-frameworks.pdf
Pro 2.6 will be out very very soon, so check My Esri for updates
RitikaPrasai1
Thank you , but though i installed the tensorflow-mkl 1.13.1, the problem has not been solved yet
DanPatterson
You just don't install that tensorflow-mkl 1.13.1 unless it applies to your use case and environment.
Done here... it might be your hardware and/or software combination since "some" people seem to get it to work
RitikaPrasai1
Thank you!
by Anonymous User
Not applicable
You will get errors when entering the trained model file if not all of the deep learning framework packaged are installed. Please see Install deep learning frameworks for ArcGIS—ArcGIS Pro | Documentation  for the complete instructions on how to install.
RitikaPrasai1
I was able to run the file-but did not get the result when I run 'classify pixels using deep learning'- it says pro has encountered unknown error please contact esri technical support. Everything is correct and it doesnot have any error while giving inputs- it encounters error when i try to run it. Could you suggest me on this?
DanPatterson
As it says, contact Technical Support is your best option
