Data Gone from D2M but in on my computer
4745
09-21-2016 12:03 PM
ClayTumlin
I downloaded Drone2Map this morning and processed 80  images... everything processed and showed up... I closed out of D2M and now upon reopening D2M, none of my data shows up.  Even double clicking the filename.d2m only opens the program and does not load the project.
Nothing shows up under my data nor 2d Projects in the TOC.
Drone2Map for ArcGIS 1.0.1.498
BrigThomas
I have the same problem in both 2D and 3D.
JamesTaylor3
Esri Alum
In Drone2Map 1.0 and 1.0.1 double clicking a *.d2m file doesn't open the project, that feature is being released in version 1.1.
As far as the missing data a couple things to check:
I assume you reloaded the project via "Open" on the "Project" tab and 2D Products in the Table of Contents is empty?
Check C:\Users\<user>\Documents\Drone2Map Projects\<project>\products\2D for tiff files
  1. If you can send me the log file in a message I can diagnose this for you.
  2. Edit %LOCALAPPDATA%\Programs\ArcGIS\Drone2Map\Bin\data\config\log.json
  3. Change the logLevel to "debug"
  4. Start D2M, open the project and run processing
  5. Send me %LOCALAPPDATA%\Drone2Map\log\d2m.log
BrigThomas
To Clarify the products are there. The ortho tif, 3d pdf, etc are being created and saved to disk where i tell it to. The problem comes when I want to go back into that project and view the tif, or 3d mesh in drone 2 map, the data is missing from the table of contents.
B
Brig Thomas
GIS Tech III
Central Utah Water Conservancy District
www.cuwcd.com
V. (801) 226-7137
( tel:8012267137)
C. (801) 787-8055
>>> James Taylor \products\2D for tiff files
Reply to this message by replying to this email, or go to the message on GeoNet
( https://community.esri.com/message/639109-re-data-gone-from-d2m-but-in-on-my-computer?commentID=639109&et=watches.email.thread#comment-639109)
Start a new discussion in Drone2Map for ArcGIS by email
( mailto:[email protected]) or at GeoNet
( https://community.esri.com/choose-container.jspa?contentType=1&containerType=700&container=4573&et=watches.email.thread)
Following Re: Data Gone from D2M but in on my computer
( https://community.esri.com/message/639109-re-data-gone-from-d2m-but-in-on-my-computer?commentID=639109&et=watches.email.thread#comment-639109) in these streams: Inbox
This email was sent by GeoNet because you are a registered user.
You may unsubscribe
( https://community.esri.com/unsubscribe.jspa?email=brig%40cuwcd.com&token=f426bfd47b9bfa1c9e54f136011958f179cc6652dc37b57d4d8c9e73d47b2b3e) instantly from GeoNet, or adjust email frequency in your email preferences
( https://community.esri.com/user-preferences!input.jspa)
JamesTaylor3
Esri Alum
I looked at the logs. It looks like the problem is a known issue in Drone2Map 1.0.1 in that projects don't load properly when the Organization in AGOL is set to HTTPS Only.   If you like you can verify this by turning this option off in your org:
  1. Login as admin user
  2. Click My Organization
  3. Click EDIT SETTINGS
  4. Click the Security tab
  5. Uncheck Allow access to the organization through HTTPS only.
This issue has been corrected in Drone2Map 1.1 which will be released after the end of the year.  Sorry for the inconvenience.
BrigThomas
Thanks
Yes I currently have the box checked to only allow https.
Brig Thomas
GIS Tech III
www.cuwcd.com
V. (801) 226-7137
( tel:8012267137)
C. (801) 787-8055
>>> James Taylor <[email protected]> 10/5/2016 2:27 PM >>>
GeoNet
( https://community.esri.com/?et=watches.email.thread)
Re: Data Gone from D2M but in on my computerreply from James Taylor
( https://community.esri.com/people/james_taylor-esristaff?et=watches.email.thread) in Drone2Map for ArcGIS - View the full discussion
( https://community.esri.com/message/639277-re-data-gone-from-d2m-but-in-on-my-computer?commentID=639277&et=watches.email.thread#comment-639277)
( https://community.esri.com/message/639277-re-data-gone-from-d2m-but-in-on-my-computer?commentID=639277&et=watches.email.thread#comment-639277) in these streams: Inbox
You may unsubscribe
