D2M ortho distortion
897
12-15-2021 08:25 AM
ChristiHallman
Hi there. I am experiencing distortion issue with the orthomosaic. I processed the same set of images (77) in Pix4D and in Drone2Map and got different results. The spatial reference data is the exact same for both images. The same settings were used in the processing (including camera internal opitmization for rolling shutter). Any ideas why D2M would be distorting this image? Thanks kindly.D2M orthoD2M orthoPix4D orthoPix4D ortho
FrankOuyang
Hi, can you highlight the regions in the imagery with the distortion? I flipped between them but couldn't identify. Also, two images are not showing the exact same extent so it is hard to compare.
