convert *tiff file to *ecw file in Drone2Map
2867
03-23-2023 12:59 PM
ValmirSantana
I would like to know if it is possible to convert *tiff file to *ecw file or another file that has the same size in Drone2Map. Does anyone here have an idea?
Tags (1)
GordonSumerling
Hello @ValmirSantana The outputs from D2M are all tiff files. Conversion to ECW is not available as this is a licensing restriction from Hexagon. Only Hexagon products can write or update ECW files. If you take the image into ArcGIS Pro you can use the Copy Raster tool to convert to Jp2 which can provide equivalent compression.  Personally, I would leave as tiff as it is transportable to other applications. If you just want as backfround imagery then CRF is a faster option than JP2.
HTH
Gordon
ValmirSantana
Thank you for your concern and for your clear answer, @GordonSumerling
