Thank you for your help, that is great!
I have another question:
We have install ArcGIS 10.5.1 on one of our PC recently. I have joined admin polygon with xls file. Then when I open the qury builder, I see the following and the same is true when I open attribute table and label expression. Please any help on this issue.Kind regards,Zeleke
On Friday, November 3, 2017, 1:54:40 PM GMT+3, Jayanta Poddar <geonet@esri.com> wrote:
#yiv6712748469 * #yiv6712748469 a #yiv6712748469 body {font-family:Helvetica, Arial, sans-serif;}#yiv6712748469 #yiv6712748469 h1, #yiv6712748469 h2, #yiv6712748469 h3, #yiv6712748469 h4, #yiv6712748469 h5, #yiv6712748469 h6, #yiv6712748469 p, #yiv6712748469 hr {}#yiv6712748469 .yiv6712748469button td {}
Re: When I nistal arcGIS 10.4.1 on windows 7, it says Service pack is not installed
reply from Jayanta Poddar in ArcGIS Desktop Installation support - View the full discussion
No. It is just a patch, not an OS version. So, it won't format your machine. You can go ahead with the installation of SP1 for Windows 7.
All applications will remain intact.
Reply to this message by replying to this email, or go to the message on GeoNet |
Start a new discussion in ArcGIS Desktop Installation support by email or at GeoNet |
Following Re: When I nistal arcGIS 10.4.1 on windows 7, it says Service pack is not installed in these streams: Inbox |
This email was sent by GeoNet because you are a registered user.
You may unsubscribe instantly from GeoNet, or adjust email frequency in your email preferences
