When I nistal arcGIS 10.4.1 on windows 7, it says Service pack is not installed
7555
5
11-03-2017 02:32 AM
ZelekeKebebew
When I install arcGIS 10.4.1 on windows 7, it says Service pack is not installed
JayantaPoddar
As a prerequisite, you need to install Service Pack 1 of Windows 7 before installing ArcGIS Desktop.
Install Windows 7 Service Pack 1 (SP1)
Download Windows 7 and Windows Server 2008 R2 Service Pack 1 (KB976932) from Official Microsoft Down...
After installing SP1 for Windows 7 (Restart the system if required), you could install ArcGIS Desktop.
Think Location
ZelekeKebebew
Thank you so much for your information. But is it not formatting my PC and losing all applications?
Kind regards,Zeleke
On Friday, November 3, 2017, 12:46:26 PM GMT+3, Jayanta Poddar <geonet@esri.com> wrote:
#yiv6690954510 * #yiv6690954510 a #yiv6690954510 body {font-family:Helvetica, Arial, sans-serif;}#yiv6690954510 #yiv6690954510 h1, #yiv6690954510 h2, #yiv6690954510 h3, #yiv6690954510 h4, #yiv6690954510 h5, #yiv6690954510 h6, #yiv6690954510 p, #yiv6690954510 hr {}#yiv6690954510 .yiv6690954510button td {}
GeoNet
Re: When I nistal arcGIS 10.4.1 on windows 7, it says Service pack is not installed
reply from Jayanta Poddar in ArcGIS Desktop Installation support - View the full discussion
Download Windows 7 and Windows Server 2008 R2 Service Pack 1 (KB976932) from Official Microsoft Download Center
Reply to this message by replying to this email, or go to the message on GeoNet
Start a new discussion in ArcGIS Desktop Installation support by email or at GeoNet
Following Re: When I nistal arcGIS 10.4.1 on windows 7, it says Service pack is not installed in these streams: Inbox
This email was sent by GeoNet because you are a registered user.
You may unsubscribe instantly from GeoNet, or adjust email frequency in your email preferences
JayantaPoddar
No. It is just a patch, not an OS version. So, it won't format your machine. You can go ahead with the installation of SP1 for Windows 7.
All applications will remain intact.
Think Location
ZelekeKebebew
Thank you for your help, that is great!
I have another question:
We have install ArcGIS 10.5.1 on one of our PC recently. I have joined admin polygon with xls file. Then when I open the qury builder, I see the following and the same is true when I open attribute table and label expression. Please any help on this issue.Kind regards,Zeleke
On Friday, November 3, 2017, 1:54:40 PM GMT+3, Jayanta Poddar <geonet@esri.com> wrote:
#yiv6712748469 * #yiv6712748469 a #yiv6712748469 body {font-family:Helvetica, Arial, sans-serif;}#yiv6712748469 #yiv6712748469 h1, #yiv6712748469 h2, #yiv6712748469 h3, #yiv6712748469 h4, #yiv6712748469 h5, #yiv6712748469 h6, #yiv6712748469 p, #yiv6712748469 hr {}#yiv6712748469 .yiv6712748469button td {}
GeoNet
JayantaPoddar
It would be better if you could write a separate question for this issue. It would be helpful for the people with similar issue (to find the thread) in future.
Think Location
