ArcGIS Extension Authorized but not installed
949
11-29-2018 01:32 PM
ChristinaHoddinott1
Okay, so I'd like to use "Quick Import" in Data Interoperability toolset. However, when I try to open it a little red "X" shows up next to the tool (see picture). When I looked into my licensing, I see that I have the toolset authorized, but not installed (pictured). Now how in the world do I get it installed? I tried updating my installation via setup.exe, but I could find anything that related to this particular toolset to change.
V_StuartFoote
MVP Frequent Contributor
Safe Software FME based Data Interoperability is distributed in a separate installer "ArcGIS Data Interoperability for Desktop" built for each release of ArcGIS Desktop is available via the my.esri.com Customer portal.
ArcGIS Pro also has a dedicated installers for its builds.
Access your my.esri.com portal--or contact whomever is your Esri primary contact for access.  Download the appropriate installer, be sure to "run as administrator" when you install.
