Upgrade requirement not met
8807
12
08-13-2018 10:31 AM
AKINAkintuyi
Greetings all, kindly help with the installation of ArcGIS Desktop 10.6.1 with error of "upgrade requirement not met"  on Windows 10
LaureneKoman
Please post a screenshot of the message.  Thanks
AKINAkintuyi
Here is the screenshot. Thank you.
DanPatterson_Retired
again...
AKINAkintuyi
See the screenshot as requested. Thanks.
your screen isn't attaching.  If your respond to your thread, not via email notifications, but by clicking on the title. you should see a "Use Advanced editor" link to the top right of the thread you are writing in.  You have to use the advanced editor to see the Attach link.  When attaching, you must wait until it is fully loaded before you complete the post
AKINAkintuyi
Thank you for response. See the attached.
XanderBakker
Esri Esteemed Contributor
It would have been nice if the error message included info on the "other products" that are causing the conflict. Do you have any other products installed with a dependency on ArcGIS? Any software open / active during the install? From what version are you upgrading?
AKINAkintuyi
I had ArcGIS 10.3.1 running on my system and uninstalled it before trying to install 10.6.1. After extraction, the system started installation and checking for system requirement before prompting this error message "Upgrade requirement not met" and the same message when trying to reinstall 10.3.1.
LaureneKoman
Please provide a screenshot of the ArcGIS Products listed in your Uninstall Programs.  Make sure to include the version column.
Thanks
Laurene
