unable to install 10.2.2 desktop student edition. Permission problem
4609
02-22-2015 09:55 PM
MichaelAsher
I'm attempting to install 10.2.2 Desktop Setup and I'm getting an error message:
Error 1303. The installer has insufficient privileges to access this directory: C:\Program Files(x86)\ArcGIS\Desktop10.2\TemplateData.  The installation cannot continue.  Log on as administrator or contact your system administrator.
I'm the administrator on my Windows 7 laptop and I'm unable to change permissions for the TemplateData folder.  I did go back and make sure I had write privileges as administrator.
Michael Asher
KishorGhatage
You could try following:
1 Click on the start button > right click on the 'Control panel' > show on desktop
2 Right click on Control panel > Create shortcut
3 Right click on the shortcut > Properties > Shortcut > Advanced
4 Select run as administrator > Click Ok
5 Now open control panel using the shortcut and try to uninstall ArcGIS.
Hope this is helpful
Kishor
KishorGhatage
Please try :
ArcGIS 10.2.2 Uninstallation Utility for Windows
http://resources.arcgis.com/en/help/uninstall-guides/1022FinalUninstallUtilityGuide.html
AndySmith
Hi Michael,
Please see the following KB article that should help resolve your issue:
16274 - Error 1303 or Error 1310
