I have a technical issue with ArcGIS Desktop... I'd like to speak with technical support. where do I get help?
1144
08-09-2019 11:42 AM
JonathanBoright
When I save an .mxd and then subsequently open it... there is no content. It is blank.
If I 'save-as', then the older version remains intact, but the new one is wiped clean.
I tried upgraded to a fresh install of ArcGIS 10.7.1, but the issue remains.
KoryKramer
Esri Esteemed Contributor
If you're current on maintenance, you should be able to submit a case with technical support: https://support.esri.com/en/contact-tech-support
KoryKramer
JonathanBoright
Thanks! ...I just did.
