HOW TO SET THE LISCENCE
3150
6
06-13-2016 02:11 AM
PatrickSalasini
WHEN  START THE PROGRAME ARCH 10.4 IF FAILING TO DISCOVER THE LISCENCE SETTINGS
DanPatterson_Retired
for the trial version, see ArcGIS for Desktop | Free Trial andits help and video
for purchased or institution versions you will get a license file by email once registered
PatrickSalasini
Thanks Dan,
its a trail version and it not passing the loading stage. it is not starting but just saying it could not find the licence,
You need to follow the instructions and register it first.  Once that is done, you will receive a license
PatrickSalasini
alright will give you feed back..
JayantaPoddar
Have you followed these steps?
Install and authorize
  1. Once the ArcGIS 10.4 for Desktop software download is complete, extract the installation files to a destination folder of your choosing. If you prefer, you can automatically launch the setup after the files have been extracted.
  2. When prompted, select ArcGIS for Desktop Advanced (ArcInfo) Single Use. Click Authorize Now.
  3. On the Authorization Options dialog, check the 'I have installed my software and need to authorize it' option and click Next.
  4. Enter your authorization number: EVA123456789 (*Replace with the appropriate authorization no. in the mail), and click Next.
  5. On the Authorize Software Extensions dialog, select 'I do not want to authorize any extensions at this time' and click Next. (Ten ArcGIS for Desktop extensions are automatically authorized with ArcGIS for Desktop Advanced (ArcInfo) Single Use, and therefore it is not necessary to authorize extensions at this step).
Think Location
PatrickSalasini
Thanks for your contributions everyone,  you have really helped out a lot and I have successfully opened the software.
