Error Installing ArcGIS Desktop 10.8.1
9979
13
12-04-2020 05:20 AM
OlanrewajuLawal
I am trying to upgrade my ArcGIS 10.8 to 10.8.1. Once the installation starts the error (see attached image) shows up. However, I have installed and reinstall the missing Microsoft redistributable package.
I don't know what else to do.
Is there any suggestions on what to do?
Cheers
AlaDinKambo
I'm facing the same problem is there a solution?
curtvprice
This is a system specific thing (particular Windows install "state") - apparently based on the thread. Highly recommend contacting Esri support on this issue.
In general installing using the Setup.exe instead of the MSI will update the redistributable for you. If it does not, contact Esri support for help.
Mike_Tulis
We worked with ESRI and Microsoft on this issue. Ultimately ESRI wrote us a bypass to resolve this issue. I recommend contacting ESRI.
JoséLuisGonzálezB
Hello
I had the same problem; the apparent problem was that the Microsoft Visual C ++ 2013 Redistributable (x86) version was installed on my laptop. I was able to fix it by uninstalling the Visual C ++ 2013 (X86) version and installing the latest version (Microsoft Visual C ++ 2015 - 2022 Redistributable (x86).
