Error Code = LF01
5608
8
03-07-2016 09:07 AM
Stefande_Vries
Tijdens het starten van ArcMap krijg ik de Error Code = LF01. Wat is een oplossing om ArcMap alsnog te starten?
When starting ArcMap I get Error Code = LF01. What is the solution?
AdrianWelsh
MVP Honored Contributor
I haven't seen that before and have not found any documentation on it. Is it possible that it's a licensing issue? Do you have an appropriate ArcGIS license checked out to you?
Stefande_Vries
I downloaded the 60 day trial. I assume that the license then simply arranged.
AdrianWelsh
Have 60 days passed since downloading the trial?
Scott_Jeffrey
I have installed the 1 yr student version on my laptop to reflect the same software that my students use.  I haven't had any issues until yesterday. I am currently running 10.3.1 and was working with ArcCatalog and ArcMap open and functioning.  My machine started to bog down so I closed out ArcMap and re-opened it only to get errors for both saying that ArcGIS has encountered serious application error and is unable to continue (the usual crash error pop-up).  I tried opening up the Advanced Utility to see if there were any issues of if anything had been changed to create a problem and got the following error (similar to that pointed out in this thread):
I went looking for any patches and didn't see any related to 10.3.1.  I ran patchfinder so here is what I currently have on my machine:
License Manager shows the following:
Any thoughts on how to get my ArcMap Suite back up and functioning?  As I said. the current installation was running fine until yesterday.
Scott Jeffrey  MS, GISP
Professor and Program Director
Geospatial Applications Program
School of Applied and Information Technology
Community College of Baltimore County, Catonsville Campus
JayantaPoddar
You need to upgrade all the products to ver. 10.3.1 including License Manager (screenshot showing it is currently in ver. 10.2.1).
Other products (to be upgraded) include Data Interoperability extension and Background Geoprocessing (64-bit).
Think Location
V_StuartFoote
sjeffrey
The clip you show is for ArcGIS Adminstrator not the ArcGIS License Server Administrator.  Just stop the license server, return any licenses to your my.esri account and uninstall License Manager--it is _not_ necessary with the 1yr Education seat for ArcGIS for Desktop.
And then as Jayanta suggests, uninstall the 10.2 builds of the extensions--and if needed install the 10.3.1 build of Data Interoperability and Background Geoprocessing.
Uninstalling the License Server should clear the LF01 error.
Stuart
Scott_Jeffrey
Stuart,
Thanks for the reply. I will update the older software versions (should have picked up on that, eh..) but as I noted to Jeyanta everything was running fine until yesterday and I am not pulling any license info from the server.  This is a standalone licenses on a laptop I use to replicate the setups that students use for loading the software onto their laptops/home machines.  Guess it just caught up with me.  I will let you know what happens after the update.....
Scott
Scott_Jeffrey
Thanks for the reply. I will update the older software versions (should have picked up on that, eh..).  This is a standalone licenses on a laptop I use to replicate the setups that students use for loading the software onto their laptops/home machines.  Guess it just caught up with me.  I will let you know what happens after the update.....
